RE: Schumacher Fusion
Never heard of a turbo plate do you mean turbo plug?? Do you know what size this Novarossi motor is?? The stock fusion chassis is not setup for a non roto-start motor. This means that if this Novarossi motor does not have a pullstart or a roto-start mechanism you won't be able to fire it up. If you still have the stock tires on it you might want to switch out to foams. Foams will give you better traction.
