RE: Ziroli small 70" P-47D.. what glow engine to use?
Hey why don't you check on this 3W. Very powerfull and relyable engine...
Hubvolumen / Cylinder capacity / Cylindrée 28,5 ccm / 1.74 cu.in
Leistung / Power / Puissance 3,2 PS / HP / CV; 2,35 kW
Bohrung Ζ / Bore dia. / Alesage 36 mm / 1.42 in
Hub / Stroke / Course 28 mm / 1.10 in
Drehzahlbereich / Speed range / Vitesse de rotation 1500 - 8500 min-1 / rpm
Gewicht / Weight / Poids 1210g / 2.67 Ibs - incl. Zündung / ignition
Kurbelwelle / Crankshaft / 3 Kugellager / 3 Ball bearings / 3 Roulement Ã* billes
Pleuel / Connection rod / Bielle Nadellager an beiden Enden / Needle bearings on both ends / Roulement Ã* aiguille aux deux cotés
Benzin / Gasoline-Version 1 : 50 - 1 : 80 Mix
IIS - Zündung / IIS - Ignition / V.cc allumage 6,0 V
Propeller / Hélice 2-Blatt / 2-bladed / Ã* 2 pales:
16 x 10; 18 x 8; 18 x 10; 20 x 8
3-Blatt / 3-bladed / Ã* 3 pales:
16 x 8; 16 x 10
Regards
Johnnie Red
