RCU Forums - View Single Post - BME115 or DA100?
Old 02-15-2007 | 11:37 AM
RTK's Avatar
RTK
Default RE: BME115 or DA100?
dbcaster,
Every installation is a little bit different. I would go with the easiest first and work your way from there. If you are very rich it will make the situation worse. Also make sure the carb venturi opening has enough between it and the cowl.
