RCU Forums - View Single Post - Sig something extar Build
Old 02-15-2007 | 01:56 PM
  #74
pt40crasher's Avatar
pt40crasher
Default RE: Sig something extar Build
K. You might also consider installing a different tailwheel assembly than the kit comes with. The supplied tailwheel setup is prone to ripping the rudder off from what I have gleaned in the many other threads about this plane. I used a Dubro unit that mounts to the fuse and is only steered by the rudder. Looks good, I'm looking fwd to seeing your covering. RCKen's control surface covering method is gold.
