RCU Forums - View Single Post - BME115 or DA100?
Old 02-15-2007 | 02:13 PM
dbcaster
Default RE: BME115 or DA100?
I did open up a hole under the carb. The carb plate is very close to the front of the cowl in what could be a pocket of air. I added a nipple and fuel line from the carb plate to inside the fuse. I will try that and see what that does. I will also lean it out a bit. I am sure I was rich on the high.
