RCU Forums - View Single Post - Help attaching wing
Old 02-15-2007 | 04:55 PM
aerowoof
Default RE: Help attaching wing
with out the spars connecting the two halves togethet you may have to do what the glider guys do.use music wire secured in the fuse with brass tubes in the wing panels and slide them on.you need two one thick wire 1/4 at the main spar locaction and 1/8 just in front of the trailing edge.only other choice would be to make the struts functional other wise the wing is going to fold.
