RE: Sig 4 star 60 build
Thanks Guys, the info helped alot.
The only bashing will be adding some wing tips, maybe 3/4" balsa blocks on each side, and sanding to shape.
I may try to make the fuse top in front removable with some wood blocks and screws, and hope it doesn't flutter in flight.
Looks like Hitec will be the choice, either HS475HB, or HS225BB both come with metal gears, they fit the pocketbook as well.
Brian
