RCU Forums - View Single Post - OS 46 Engine Losing Power.
Old 02-16-2007 | 09:10 AM
extra260bum
Default RE: OS 46 Engine Losing Power.
Check the compression, close the throttle all the way and turn the prop by hand and make sure you have good compression. Also check the carbueurator and make sure that it's tight. If all that checks ok then make sure you're not running the engine too rich, that will keep it from running at full rpm. If you haven't got one yet, a small handheld tachometer is a good investment to help you tune your motors.
