RE: 2 profiles
Got the box UPS after I left the office yesterday.
Single boxed! Yea, one thin box, but it made it in good shape.
Here are the specs from Atalanta Hobby web site;
Specifications
Wing Span: 61 in / 1550 mm
Wing Area: 1006sq in / 64.9 sq dm
Flying Weight: 5.7 lbs /2600 g
Fuselage Length: 56.5 in /1435 mm
Engine Required: 2c 0.60 cu in, 4c 0.70 cu in
Empty weight 2.3 Pounds
Mojo 60" is 1000 sq in, so this is similar in size.
The wing is straight - no taper any direction.
All the control surfaces are very small. This is going to be the downfall of this plane. If it lives to mid summer and flys decent at all I may build new surfaces. For now I'm gonna use all the stock parts.
I'll let you know as it comes together.
