RE: BVM Mig 15 build
John, can you explain the set up again, as I did not grasp the gist of the linkage adaptation. Would you also explain how the wing markers are linked in your model to the flap position.
Any info on the elevator conversion would also be good.
Fitted the splitter landing light this afternoon, and together with the vac formed clear plastic cover it looks the part - certainly bright enough to be highly visible during the day light.
Later...
