RE: Power vs. Weight vs. Reliablity vs. Ease of Use vs........
Unless you are mounting the tank on the cg, a regulator is really not needed. Saito's draw fuel well and don't even need muffler pressure if the tank is mounted correctly. All a regulator does is provide a constant fuel head for the carb to draw from.
