RCU Forums - View Single Post - Sig something extar Build
Old 02-16-2007 | 05:57 PM
  #85
cmstone
Default RE: Sig something extar Build
Is the gap at the TE? If so it may pull in when you draw the wings together with rubberbands, zipties or whatever. They should sit flush before hand though.Check the fit without the wing joiner tube installed.I had somewhat of the same problem.The wing joiner tube was slighty bent.
