RCU Forums - View Single Post - Upgrading a DF kit
Old 02-18-2002 | 07:30 PM
jettadic
Default static thrust
BVM catalogue that has some figures in it states:
With a BVM .91R @ 24,000 RPM static thrust should be 13+lbs.
I weighed a fan unit, engine and and pipe, all BVM. Weight is 3lbs.
Does anyone make inlet reducer, bypass and tailpipe for 700 yet. If not who should we contact to have them made?
I have a Viper that I would like to convert to turbine power. Right now the dry weight is 11lbs. If we can reduce weight 1-2 lbs. with turbine power the performance should be ok with 7lb thrust turbine. Right? Any info would be appreciated. TIA
Mike
