RCU Forums - View Single Post - Single or dual conversion?
Old 02-17-2007 | 09:21 AM
trevormatney
Default RE: Single or dual conversion?
Ok, so I double checked my crystal, and frequency, and everything is the way it should be. I'm using a hitec single conversion crystal 72.050 MHz. This particular receiver is auto shift, and the directions state " If you need to match the shift type (negative to positive), between Tx and micro 05s, with power OFF and ON of micro 05s, youcan easily synchronize shift type (Tx is still power on status)". After trying this I'm still getting no response. Could it be that I have a bad receiver, or crystal? All servos and battery are plugged in with the black wire toward the bottom of the receiver. Any other thoughts? I appreciate your help!
Trevor
