RE: Lock the Diff???
The picture should explain axle C's to you.... A DIG allows you to lock the axle(s) you can have front dig, rear dig, or both. It is controlled with a servo connected to the driveline. I have yet to do one so I don't know how to as of yet, but have seen many use this set-up and it works well. Dezfan may be able to help with the setup part.
