RCU Forums - View Single Post - Ultra Stick 60
Thread: Ultra Stick 60
Old 02-10-2003 | 12:44 AM
rcpilot44
Default Ultra Stick 60
Thanks!!! You're plane looks great. You probably don't notice that you had added weight since you flying with the YS 91. I will probably go with the YS or the Saito. It looks like you're using Hitec servos in the tail, what number are they and what brand and size tank are you using??
I have never built a plane with the servos mounted on the fuselage. Did you just cut out a hole for the servo and then screw them down directly to the fuselage or did you drop a servo tray in it??
