RCU Forums - View Single Post - Raising compression for zero nitro
Old 02-17-2007 | 03:08 PM
P-40 DRIVER's Avatar
P-40 DRIVER
Default RE: Raising compression for zero nitro
You could do the same thing using a little algebra if you knew the comp ratio of the engine in question. I suspect using 9 to 1 as stated above would be close enough to start with.
area of bore x stroke + Y = comp ratio x Y where Y is the volume of the head + volume of the bore above the piston at tdc.
