RCU Forums - View Single Post - Compression leak on ST 51?
Old 02-17-2007 | 03:29 PM
speedster 1919's Avatar
speedster 1919
Default RE: Compression leak on ST 51?
Well good ? Just put a squirt in carb throat. Probably about an eye dropper full. If you use the exhaust method -you watch the fuel tube at carb and when the fuel reaches carb a couple extra turns of the prop is usaully enough.
