RE: Greasing the Hacker gearbox
Did it! Kind of easy once I figured it out. The only problem I had in conceiving the fix is the printout is for the Comp motor which uses screws and my motor threads the gearbox directly on the motor. (Like was mentioned in the directions on the other thread). I didn't see the "wavy" washers that Todd mentioned and I was extremely careful to watch for them. I did see some C-clips under the gears, but no washers. Oh well, maybe I'll send it in next time so they can check it out and see if those washers are missing.
Thanks again for all of your help.
John
