RE: Engine problem - piston & sleeve (HELP)
No you did and so did Wade - AllAboutFun, and I had it running again a few min ago just fine.
One prob though is when I am trying to pull start it and it fires up, it seems that the pull string goes limp (for a lack of better terms) until I stall it or cut it off, then the tension is restored to the pull string.
Is this normal, and could this cause a problem? Should I replace the pull start?
