RCU Forums - View Single Post - Can I use a 6 cell, 7.2 volt reciever pack with stock Maxx electronics?
Old 02-17-2007 | 06:14 PM
Uglysteve
Default RE: Can I use a 6 cell, 7.2 volt reciever pack with stock Maxx electronics?
YOu can use a higher voltage battery as long as you also use a regulator between the battery and the RX that will lower the voltage to 6v. Why you would want to is beyond me because of the added weight of the SC battery packs. BUT IT CAN BE DONE RIGHT!!
