RCU Forums - View Single Post - blade cx2 help
Old 02-17-2007 | 07:53 PM
ArrowNaughtic's Avatar
ArrowNaughtic
Default RE: blade cx2 help
kruser.......... be patient there buddy,
I own a cx2 and love its stability and also the fact that it can be upgraded...however, it is NOT and outside machine unless you have a perfectly windless day. Some in here will disagree with me, but for a beginner, definatly not. It is very stable and as long as you keep in mind it doesn't fly itself, you will do fine! Go slow.........have fun and be responsible.
I just got back from the LHS and bought up 8 pairs of upper and lower blades, and a new outer main shaft as it was bent and I am too lazy to spend alot of time straightening it. At 3.99 for 2 sets of blades per upper and lower, cheap fixes and easy to install parts. You will do well with one and should get a lot of enjoyment out of it and be able to bling it out as you go along.
__________________________________________________ ______________________________
Of all the things I ever lost..................................... I miss my mind the most!
