RCU Forums - View Single Post - TT's High Performance Carbon Blades!!!!
Old 02-14-2002 | 02:15 PM
GasserMan
Default TT's High Performance Carbon Blades!!!!
Guys,
I just received a set of TT's new "high performance carbon graphite rotor blades" in white gel coat. They're made in Germany and look very similar to the Evolution 3D - Gamma blades MA sells. You know... the ones no one (even MA & HeliProz) can get.
Here are the specs...
Carbon graphite, 680mm length, 12mm root, 176 grams, 4mm bolt hole with 5mm bushing included, 58.8mm chord, symmetrical with no washout, white gelcoat, metal reinforced root.
The finish is decent and they're very stiff.
Check them out here...
https://secure.ioncart.com/helihut/c...819.jpg?id=148
GasserMan
