RCU Forums - View Single Post - Glassing & Resin Viscosity?
Old 02-18-2007 | 02:58 PM
HighPlains
Default RE: Glassing & Resin Viscosity?
It sounds like polyester resin (14 drops) instead of an epoxy. You can get polyester resin that is made for multiple layers and it stays slightly tacky, so you can keep adding layers. What you want is a finishing resin. Also if it is a polyester, it will not set up over some epoxies. In those areas, you need a barrier layer, like a thin film of white glue.
