I use epoxy.
Let it dry hard.
Make sure that the glue doesn't rise higher than the ridges on the sand paper.
ORIGINAL: Timbotide
I found a 2-1/2" DB spinner for $15.00 so I jumped on it. All I need now is the prop nut. What type of glue do you use to hold the sanding screen to the prop? Thanks.
ORIGINAL: Geistware
I have found that dry wall sand paper is really good.
Not the sand paper for sanding wood.
Dry wall paper looks like a screen door's screen.
Glue it on the propeller and it will not slip!
ORIGINAL: jaka
Hi!
The problem with aluminum spinner backplates slipping on the drive washer when fastening the prop/spinner is easily fixed by either using a thin disc of 0,4mm aircraft plywood (best metode) between the back plate and the drive-washer using a sand paper disc (not too good).
