RCU Forums - View Single Post - Compression leak on ST 51?
Old 02-18-2007 | 09:45 PM
buzzingb
Default RE: Compression leak on ST 51?
Ringed engines don't run with as much compression as ABC engines and it is normal to have compression leak or blow-by. As the engine gets broken in the piston and ring will seal better but with alcahol engines it isn't as critical. One way to judge about what is going on in the engine is to get the tachometer out and see how many rpms it will turn say an 11X7 prop.
