RCU Forums - View Single Post - Zeque Build Glow Powered...
Old 02-19-2007 | 01:04 AM
  #113
riot3d
Default RE: Zeque Build Glow Powered...
ORIGINAL: ENO
I was wondering if there is any advantage to using the spring loaded pipe mounting system that I've seen used for holding the Hatori 821 in place as opposed to the pipe mounting brackets(silicone tubing system) that is already provided with the Hatori 821 pipe ??? Seems like alot of extra money if no advantage or need.....please advice.
Doc
The spring loaded pipe mounting system is a quick release system, you just squeeze the two springs on the side of the pipe and you can take the pipe away from the header. The one that came with the Hatori pipe require loosening of screws. Well worth the extra spending.
Adrian
