RCU Forums - View Single Post - Cheaper clear coating found
Old 02-19-2007 | 10:45 AM
bluestratos
Default RE: Cheaper clear coating found
I just finished a spit fire. I sprayed the last color -camoflage green 1 week ago. This weekend I used the krylon Satin and just about cried. Mind you, I used all Krylon paints so there should have been no incapablity issues but the first thing I noticed was that the the clear dramatically changed the color.. especially on the gray. Then I painted the cowl and found out that it fogged over the green areas! It improved as it dried but two days later there is still a smokey apperance. I also had a problem with the grey areas in that when cured.. there were strange patterns developing at random.
By the way, the spray area was about 75 deg and the can was warmed in hot water just to get that out of the way.
Best regards,
Randy
