RE: Dynaflite Chipmunk - Build
Well I am now working on the flaps and Ailerons. The left side is done, on to the right side tonight, once that is done all that is left in the construction phase is finishing sheeting the fuse, while complicated to a degree, it should not take that much time.
In going over what is left it has become clear that I am missing a few parts, most importantly, I am missing the tail wheel bracket and assembly, I have had to special order that from the LHS.
I also am thinking through ordering scale landing gear from Robart, I am not sure how I will need to retrofit the wing to accomodate the Robart gear, any suggestions?
