RE: plane advice
Try moving the battery forward or aft as far as you can before adding any dead weight. when and if you do add lead weight put it as far forward or aft as you can. (the farther out you place the weight the less weight you will need.)
It is ok to be a little bit nose heavy on your trainer but real bad to be tail haevy.
