RCU Forums - View Single Post - Why 2 Stroke Engines are more powerful than 4 stroke Engines
Old 02-19-2007 | 07:32 PM
opjose's Avatar
opjose
Default RE: Why 2 Stroke Engines are more powerful than 4 stroke Engines
ORIGINAL: ChuckW
4 strokes generally make a lot of torque so they can turn a larger propeller.
I see this quoted quite often.
Yet if you go by the manufacturer's own prop range recommendation for any given identical displacement, the same prop sizes are suggested.
e.g. a 4 Stoke .50 has the same size recommended prop for a 2 stroke .50.
Given however that the 4S .50 is producing less specific power than the 2 stroke of the same size, relatively speaking you could say that it is indeed "swinging a bigger prop".... but this IMHO seems more of a marketing ploy.
... not that I dislike 4 strokers....
However in the sub 1.00 range it's hard to rationalize paying 300.00-400.00 for a 1.2 four stroke equivalent to a 80.00 .75 2 stroke engine, if the latter is reliable.... yeah they sound and idle nicely, but for the price difference in this range, is it really worth it?
