RCU Forums - View Single Post - Shrinking Ultracote 1st Time Help
Old 02-19-2007 | 10:06 PM
Safebet
My Feedback: (12)
Default RE: Shrinking Ultracote 1st Time Help
PS: IN the 3rd paragraph from the bottom I said "Do press down on the iron", that should read "Don't press down on the iron." Use just enough pressure to lay the covering to the wood and move rather slowly. Let the heat do it's work. If you see the color changing on the covering as you move, move just a little faster. When you see the color change it is shrinking. We want the iron just hot enough to activate the glue and stick the covering.
