RCU Forums - View Single Post - E-Motor Mount for Pletti Xtra Outrunner
Old 02-20-2007 | 02:36 AM
patternflyer1's Avatar
patternflyer1
Default RE: E-Motor Mount for Pletti Xtra Outrunner
Hi Crazy, I'm not sure if it would work, but in the Evolution with the Axi, I ran the mount from Esprit models here..
http://www.espritmodel.com/index.asp...S&Category=678
Maybe you could call them to see if they have a pletty mount. Maybe they are the same as the axi. I don't know..
You could also run a budd mount, found here....
http://www.buddengineering.com/Merch...tegory_Code=MM
Which does work with the pletty...
Good luck!!
Chris
