RCU Forums - View Single Post - Help - Wing Problem - Rebuild or Not
Old 02-20-2007 | 07:05 AM
Jim_Purcha
My Feedback: (8)
Default Help - Wing Problem - Rebuild or Not
Just finished the glassing the center section of my 4 Season 40, when I discovered I goofed on the right wing panel. I built the right panel "out of square". [sm=cry_smile.gif] So ... my wing is not straight. It's only February. It's supose to have ailerons. 3/4" dihedral under each wing tip. First build again in 15 years. I built this on a wing jig and not over the plans.
How might it fly the way it's set up currently?
Should I just continue with the wing as it is or should I rebuild the entire wing again? Take it as a lesson learned.
Options Please?
ID:	625605   Click image for larger version
ID:	625606   Click image for larger version
