RE: Help - Wing Problem - Rebuild or Not
It's not just the last rib which is not square. I've built a slight trapazoidal wing panel, so the right panel sweeps slightly foward from the center section by 3/16" inch. It's not was just the last rib, I would just fix it at the wing tip.
