RE: Help - Wing Problem - Rebuild or Not
I would still square it with end caps and sand the leading edge back as far as you dare. That should get you within 1/16th. I'd call that pretty good.
Short of cutting the wing at the centerline and adding a 3/16 wedge or rebuilding it....
Again, I'd be more concerned with a twist in the wing.
