RE: What are the key elements of a sound drift vehicle?
4wd Vehicle? Definately
Shaft or Belt? Either one, I use Both
ESC? No Limit with Reverse is a BIG Help
Motor? Between 27 Turns and a 15x2T for High speed Drift
Radio? 2-channel pistol grip is advised
Tires? For low cost and maximum sliding , Poly pipe
Suspension Stock Friction is fine but Oil filled shocks are an Advantage
Camber? For Polypipe, 0-camber all way around
