RCU Forums - View Single Post - Help attaching wing
Old 02-20-2007 | 07:44 AM
iron eagel's Avatar
iron eagel
Default RE: Help attaching wing
ORIGINAL: canadagoose
Make sure that the fuse sides that the wing will be attached to can't flex and twist outwards at the front of the cabin. The wing creates both induced and parasitic drag which will want to pull on the wings in a backward direction in flight, even more so with a fat, flat bottom, under cambered or Clark Y kind of airfoil and constant chord wing. The cabin at the trailing edge of the wing will have to deal with some compressive force, the way i see it anyways.
That is why I was stresing that he glass both the top and bottom and sides of the cabin for strength as well as the inside. It is critical that the cabin structure be rigid as possible for the reasons you have stated.
