RE: Predator outrigger [project]
good stuff.
i was going to ask where your foam inserts are for the sponsons. then i remembered you got the plans.
Also the foam in the tub will pose a problem. It is not going to have much effect on the strength. so i would suggest you remove it. Heat of the motor and esc and batteries could melt that and be a fire hazard.
