ORIGINAL: joeyblaze
cann a TT01 handle a Mamba MAX 5700 BL?
what up grades would u need
i have TT01R
so i got bearings and alum drive shaft out of the box, would i be able just to drop that bad boy, then u could increase your cell count correct myabe to 8
i was more looking at the 4600kv set up says its as fast as a 12t
would this be safe for TT01R
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXNKU0&P=ML]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXNKU0&P=ML[/link]
Whats the stock shaft size?
No reason why it would not work in the TT-01R. The 4600 motor would be great for drifting...but you would NOT need to increase your cell count to 8. I am running 6 and it is fast enough for drifting.
The mamba max motor dropped right into the stock TC4 motor mount.
As far as upgrade, I think you have most of them..just upgrade as you break stuff.
URC
