cutting ailerons from trailing edge?
Lay out your cut line per plans, then use razor saw. To get a straight edge you can sometimes tape a steel rule along the cut line with masking tape, then use it as a guide to run your razor saw against. I suppose you could use a razor blade as well, but i have better control of a saw.
