cutting ailerons from trailing edge?
If you use a bandsaw, make the root cut first, turn the saw off, and back the wing out. Then make the cut along the lenght. Much easier to back to saw out of the short cut thna the long cut. Use the widest blade your bandsaw can hold for the straightest cut.
ML
