RCU Forums - View Single Post - How to remove flywheel from GST
Old 02-21-2007 | 03:17 AM
Scott_GTR's Avatar
Scott_GTR
Default RE: How to remove flywheel from GST
Pop the clutch shoes out, then take the large nut off using the wheel nut box wrench.
The flywheel is on a taper, so you will have to get a large flat screwdriver behind it and twist.
Don't do what I first did and spend 30 mins rotating it before realising it is not unscrewing!!![&:][&:][&:]
Your Hand Book will show this assembly in and exploded diagram.
