RE: E-Motor Mount for Pletti Xtra Outrunner
Hallo Chad
My secound plane is a ZN Synergy with the Pletti Evo and.... and.... The same setup you have in your twister.
I will copy your motor mount. I saw and read in your build report from your Twister. The idea with the Ring on the backside is very good. What you think about Balsa front wood instead of plywood, with carbon.
thanks for help
