RE: Zeque Build Glow Powered...
No Mola your wrong I just talked to Mickey. They have the super mount that you show in the picture. The problem is the rails are not set right on Doc's plane and others who have the plane are experiencing the same problem. Except Chris who placed the Axi in his. (Good move Chris)!
Mickey had to shim the YS mount to bring the spinner backplate in line with the nose. It required a .100 shimm on the back of the mount and a .062 shim on the front. Oxai made a mistake. The manufacturer is going to be notified of the problem. It's fairly easy to fix but surprising when 1st discovered.
Good news is the early flight reports on the plane seen very positive. This was reported on the Electric Zeque thread. Mike
