RCU Forums - View Single Post - Zeque Build Glow Powered...
Old 02-21-2007 | 10:22 AM
  #118
Troy Newman
Default RE: Zeque Build Glow Powered...
This change could be by design. I have Rusty Dose's Zeque in my shop right now. When I get home from flying tonight I will look at this issue. I think perhaps there could have been a chnage in the amount of down thrust needed after the protype was made. Oxai then lowered the beams to allow shims to adjust this. If they put the rails to high (looking from the bottom) in the fuse then you can't adjust anything without grinding the YS Super Mount spacers. But by lowering the beams in the engine area now you can add shims to get the downthrust correct.
I have a spare engine and YS mount and will stick it in Rusty Dose's model tonight.
We have been really busy with setting up the field for the PHX event, and also out practicing.
I have spent all weekend at the flying field marking the box lines and installing poles. They are correct and setup just like the NATS. Boy its sure is nice to be practicing inside the box.
I'll let you guys know what I find.
Troy
