RCU Forums - View Single Post - Extreme Flight 88" Yak - Build and Fly
Old 02-21-2007 | 03:01 PM
Maudib's Avatar
Maudib
My Feedback: (51)
Default RE: Extreme Flight 88" Yak - Build and Fly
3d-aholic,
You got me thinking... and I always enjoy running a test or two (especially when they are this easy)
I grabbed some scrap balsa block and drilled a 3/16 hole and another one that I "wallowed out" a bit to simulate a couple potential hingeholes.
I then moistened the holes as usual... then dripped a couple drops of GGLue in the holes and pokes, swirled the stick in applying the glue well to the hole walls...
THIS time I did NOT apply ANY glue to the hinge... just poked them in.
Based on the results... (I'm still waiting on a decent cure time to test strength... I won't apply glue to the hinges again... the foaming properties of the glue does it's job... and addig it to teh hinge seems to only add a step and makes for more foaming...
You may have just helped save me some hassle and time... making hinging almost a breeze...
It still needed a little wiping at the "hingeline" as it still foamed a little... but not as much... and only ONCE...
ID:	626621   Click image for larger version
