ORIGINAL: Dannn
cesspool, you are being quite arrogant...
anyways, only go with 1 because usually with brushless motors one will be spinning faster than the other all the time and eventually it will just burn them up.
I don't think there is a need to be calling someone "arrogant" just because he has a question if it is possible to put 2 brushless motors in his Mini-LST.
Yes, it is possible to put 2 brushless motors in a Mini-LST. You will need to have 2 brushless ESC.
I have a Mamba 8000kv in mine running on 7cell 1400nimh and it is definately faster then the stock setup.
