RCU Forums - View Single Post - Help!!!, warped stabilizer...
Old 02-21-2007 | 04:05 PM
Mr67Stang's Avatar
Mr67Stang
Default RE: Help!!!, warped stabilizer...
Well, I guess I would try to use a sealing iron and a little of the heat gun and give it a go. If you can get someone to help you, you hold the piece flat to your satisfaction. This should cause a wrinkle or loose spot in the covering. Have your helper run the heat gun over those wrinkles just until they go away. Take baby steps going over the piece and you should be able to work the warp out.
