RCU Forums - View Single Post - Question about battery charge
Old 02-21-2007 | 06:29 PM
magnat
Default RE: Question about battery charge
Looking forward to the Vid
3 amp is a safe charge rate and will get you a longer run time..
You could rip 5 amps into it but charging at High Amperage tend to let the Batteries Burst the Power at a High rate but shortened run time and it can reduce the battery life..
3 amps is safe..
My Swallow advanced peaked the el-cheapo type 1800mah at 2150mah when I used a 3 amp charge
